It is currently Sun Jul 27, 2025 8:16 pm
PostPosted: Mon Jul 21, 2008 5:20 pm
I'm reading and looking at Cumpino and Natelson book and saw that He puts his X brace after finger brace, sound hole braces,bridge plate and so on.
Does it have to be this order? why not glue on the X brace and use that as a reference to shape and glue other braces?
Thanks for the help, David
PostPosted: Mon Jul 21, 2008 6:05 pm
I don't think the order matters.
I'm with you.... X first.
Mark
PostPosted: Mon Jul 21, 2008 6:20 pm
Mark
Ditto! And if you start your shaping and voicing with only the X on, as I do, this makes all the sense in the world - at least to me.
PostPosted: Mon Jul 21, 2008 6:53 pm
I believe he suggests it that way because it's easiest to clamp in that order (lowest - height wise - braces first).
If you have a go-bar deck or a vacuum system, I imagine you can do whatever you want.
PostPosted: Mon Jul 21, 2008 8:13 pm
I've done the tone bars and finger braces first. Makes it easier to taper their ends where they butt up against the X. Then the X and taper it. But this way, it makes it more awkward to do the sides of the X.
If I put the X down first, it's easier to profile the X-brace, but not as easy to do the finger braces and tone bars. In either case, the UTB and bridge plate are last, then final shaping.
So, choose your medicine. [:Y:]
PostPosted: Tue Jul 22, 2008 12:53 pm
I've gone to X first on my X braced guitars. A lot easier to butt the others up to the
X than to fit them so the X drops in with the rest nicely butted.
PostPosted: Wed Jul 23, 2008 3:02 pm
Order depends on convenience, bracing layout and clamping technique. I do my X first as all other bracing below the sound hole butts up against the X brace. I pre profile the incline that butts against the X brace on finger and tone bars prior to gluing them in place. The shave as needed to reach Zero at the opposite end with a chisel after glued up. Then use a finger plane to finish all profiling.
